takidd4597
- Feb 27, 2003
- 5
I have that 1988 mariner 60hp outboard. I recently posted a question see below: If I can't correct the problem with tightening every fuel line and rebuilding the fuel pump is there a way to install a electric fuel pump to use a idle speeds when it normally dies out? This is a big problem where I live! We have all them Manatee zones!<br /><br />I have a 1988 60hp mariner outboard that runs great at full throttle but at idle it will not stay running. The only way to get to start again or keep running at idle is to pump the primer bulb. Anything above idle is fine.<br /><br />If I pump the bulb hard it starts right up and runs for a few minute the dies.<br /><br />I have replaced the entire fuel line buld fittings and all.<br /><br />I am at a loss as to what could be causing this.<br /><br />Please help anyone.<br /><br />Thanks in advance!<br />Tim.
