Re: Electric Fuel Pump???
Even if you add an electric fuel pump, you still have the same issue that you have with the existing mechanical pump. You just moved the problem farther away from the engine. What if the pump leaks, or the line leaks between it and the carb. You just created more places for the problem to exist. You still fill the bilge with fuel. The weep hole in the old carbs is simply a vent for the non-fuel side of the diaphram. That side needs to be open to the atmosphere or the diphram may not function properly. That port can be enlarged, tapped and a fitting inserted for a separate line to the carb. You can't do that with an electric pump. The electric pump also requires an oil pressure switch connection so if the engine dies, oil pressure drops and the pump quits. I know -- you will say I will just turn off the key. I suggest as good intentioned as you are, you will not think to do that in an emergency. Here is just one scenario: Running along nicely and then pull into a cove but as you do so the engine dies (doesn't matter why). But lets just assume the reason it died was because the float stuck in the carb and with the now dead engine, the pump continues to run which is overflowing the carb. A minute or so (or longer) you attempt to restart and the now severely flooded engine goes "kaboom". This electric pump solution for what is a "non-problem" is not a rational solution unless it is carried all the way which includes the safety cut off. Just install the standard pump and add the third line. It is safe, durable, and in the end, more reliable and less expensive.
