Hi Folks,
Has anyone any experience of electric fuel pumps? In 2010 I privately purchased a 1996 Maxum 1900SR. ( Eyes wide shut. Buy in haste repent in leisure).
There were some cosmetic problems that I eventually got sorted. Have had no problems with the engine so far. There is an electric fuel pump instead of a standard pump. To my horror recently I have discovered that the pump is connected to the ignition sw and when the ignition is switched on the pump runs whether the engine is started or not. I have checked out possible solutions on the net. If I connect the pump via the starter supply on starting and then the oil pressure sw when running. I presumably have to use 2 no. relays for same. I'm not sure if a regular pump can be fitted or not. My question is (eventualy) Is an electric fuel pump harder on fuel than a regular pump as it pumps the same amount of fuel at 1200 rpm as 5000rpm. My engine is a 4.3 v6 Mercruiser. Thats all I know about the engine as my mechanicial knowledge would be fairly limited. Not sure how carb works etc.
Thanks in advance for any replies.
Iain
Iain
