Electric fuel pump
Cpotter78!
Hey guys quick question going to use a electric fuel pump in my 74 165 6 cyl. what size (pound) should I use.
Ayuh,.... Welcome Aboard,... Be sure to wire in an oil pressure switch in the power supply circuit,.....
why>
a mechanical fuel pump is $50 and will last 50 years
a marine rated electric fuel pump is $85, the required oil pressure switch and relay to wire it properly is another $15 and it will last only 5-7 years (10-15 if you are lucky)
Lou C
Exactly. I have replaced exactly three (3) mechanical pumps in 49 years of driving and 19 years of boating. In fact if I repower this boat I really want to find an engine that can use a more reliable mechanical pump. Probably will have to go with a reman 4.3
Cpotter78!
why>
I’ll stick with the mechanical thanks guys
Cpotter78!
I stuck with the mechanical fuel pump but do I have to use leaded gas or the substitute or can I just use regular gas
Lou C
The mechanical pump is just fine have run them with E10 for years with no problems.
the type of fuel is not determined by your fuel pump. it is determined if you have had your head serviced and hardened valve seats installed since your engine is a 1974. I would stick to adding the lead substitute, or get a later head.
Cpotter78!
That’s what I thought thank you
If I don’t use the lead sub should I use premium 91 octane
the octane of the fuel and the lead requirement are two completely different issues. octane is needed to combat detonation (pre-ignition). lead is used as a lubricant for the valves (that may have had a very minor effect on combating detonation)
you need the lead or lead substitute because your engine is older than 1978. or you need to swap your head or get hardened valve seats installed in your existing head.
no reason to run more than 89 octane
you could run the engine on regular pump gas, however you may have an issue later on.
