Electric Legality
SeaMasterZ@aol.com
Would using a genset to run multiple electric outboards cause problems with the law? you arent using a gas outboard!<br /> :D :confused: :D :rolleyes: :D
Re: Electric Legality
Where are you going to find a genset that'll produce the required DC Voltage,+ Ampereage,..???.....<br /><br />And,....... You'll Still need a Bank of Batteries.........
18rabbit
It depends on the laws where you are. It's regional. Best to check with your local authorities in NJ. In Calif, in some lakes it would be ok, in some it would not.
SeaMasterZ@aol.com
I was thinking of using a 110v gen and a heavy duty charger, just to keep the three 27 series RV batts up to snuff
18rabbit
If the ban on gas engines in your local lake is to prevent pollution, you may be ok. If the ban is to prevent noise or to allow wake-free use of the water resource for wind and paddle propelled vessels, you won’t be ok. Those are the two reasons that I know of in Calif for the ban of gas engines on boats on some lakes. That’s why I suggested checking your local authorities; find out what the ban is actually for. <br /><br />If you get the green light to motor out with your gen and bats, please let us know how it goes.<br /> :)
byacey
Is a nuclear powered turbine drive out of the question? It doesn't produce smoke or belch half burnt 2 cycle oil...? :D :D ;)
ndemge
sounds like your building the hybrid boat :)
