electric starter kit upgrade for 2009 NISSAN 9.8
gary - k7gld
Looking to upgrade my 9.8 Nissan 4-stroke from manual start to electric start - any one here have a pointer to a low cost source for a kit to do this? - already have installed the alternator/rectifier kit, so only need the parts relative to the starter upgrade itself.
pvanv
Re: electric starter kit upgrade for 2009 NISSAN 9.8
You may well be better off financially by swapping for an EF model. Depending on your precise model/serial, you may need up to 34 line items, and cheap they are not, especially the starter motor itself, which is over $300.00. I assume you want to upgrade an F type (tiller steered). Does your flywheel have the ring gear already? If not, that will need to be swapped out.
The full kit, including flywheel, is:
3V2763000M ELECTRIC START KIT, 8/9.8A2,A3 (F TYPE) $712.65
See the parts catalog on Elvin's website at http://www.internetoutboards.com/PartsCatalogMenu.htm
