Have a 14', Fiberglass runabout with Evinrude 50hp, (4 stroke), total boat weight with 2 people etc , about 1400lbs, (guessing) and instead of having an emergency gas kicker, weighing 50+lbs, plus maybe separate tank if its a 2 stroke, plus installing separate kicker bracket, I was thinking of a lightweight, 40-50lb thrust electric, which could mount directly to transom when needed, and since boat already has a deep cycle battery, but would it push the boat, especially against the wind or currents? it would only be for emergency use should the 50hp quit, boat is only used in saltwater, but due to cost difference, if I used a freshwater motor in salt water, then ran it in fresh water after, would it be okay, or will the saltwater cause immediate, non reversable damage. And how fast would it push my boat and how long would an electric last assuming battery is at or near a full charge, Thanks
