Electric winch instead of anchor hoist
tpenfield
Probably not enough spool capacity, so that is why a windlass. Sort of depends on the boat and anchoring needs. Tell us more, if you like.
atepoint2001
I have a 16' Tracker with 20 lb anchor. I currently have a Trac Fisherman 25 but it doesn't seem like it has sufficient power to lift my anchor. I want to replace it it and electric winches are half the price. I also like the fact that they free spool so you can get the anchor down faster.
dingbat
I would go about it a bit different and change the anchor instead of the winch.
Why are you using a #20 anchor on a 16 ft. boat?
The #17 I use on a 22ft., #5,500 boat is more than enough under far worst conditions than your boat would ever see.
your using the wrong anchor if your using a 20# anchor on a 16' boat.
the anchor on my 24' boat is a 13# danforth. on my old 16' boat it was a 7# danforth.
jsparks747
I personally would rather have the windlass than have an electric winch. I would agree with everyone else though, your anchor is too big. I use a 3.5 lb Danforth anchor with 3 feet of 1/4 inch chain on my 15 foot tiderunner and it is plenty. It matters more on how the anchor digs into the bottom than the weight of the anchor. I would rather have a 3.5 pound Danforth anchor than a 20 pound a pyramid anchor. Sure the pyramid would hold, but having something that grabs on is more important.
