Re: electrical clicking
I checked the connections at the starter and selenoid. All is well there, no crossed or touching wires. <br />The ignition switch tested good, no continuity between red and purple until switch is in run position, and nothing between red and white until in start position.<br />I made a voltage test on wire when switch was removed. red wire is hot, purple wire is hot, white wire is cold. Shouldn't the purple wire be cold until charged from the switch? I tested the connection where it would connect to the switch.<br />Back to my first thought, I hooked something backwards when I put the trim pump back in. I am thinking the whole trouble is in the rear wherever the purple wire is being charged from.<br />Does the purple wire connect to the selenoid or right into the coil? The wiring diagram helped, but leaves a few questions open. The hot red wire comes in from the amp meter right? <br />Also when I connect the battery all of the guages jump, so I am charging the acc. system constant. <br />Also probably a different problem but switch will not activate the starter motor. But that is the next problem to tackle.
