I hadn't used my mariah 202 for 2 years and decided to have it serviced etc. I contacted a new mechanic and made arrangements to have it serviced. I explained to the mechanic that I knew the batteries were dead and that I would replace my batteries (dual system) and he said no problem he would use his to make sure everything was working, there was 1 dead battery in the boat at that time.
He calls me during the day it was being serviced and asked if I had a kill switch because he could not get the boat to start. I don't and explained that to him. At that time there was 1 dead battery in the boat and he had added a good battery. He called me later and said that due to my set up he had to put 2 good batteries in to start the boat.
Question 1: in a dual battery set up with a perko switch can't you simply set the switch to the good battery and everything should work?
The story continues. I pick up the boat take it to storage and but another battery so now I have 2 new batteries and install them. I have no power to the ignition, or any of my accessories but the out drive has power.
I take the boat back to the shop. He explains that it probably is the relay on the starter ( mercruiser 350 mag with bravo 1 outdrive) and that he will diagnose the proplem and get back to me.
It turns out that the relay is blown it is replaced and everything is working now.
I am concerned because in 10 years of owning this boat I have never blown this relay before and do not want to do it again especially if I am out on the water.
Did I do something to cause the relay to blow when I connected the batteries? The mechanic speculated that having let the batterries go dead could have caused a surge when I hooked them up causing the relay to blow.
I wonder why the mechanic was able to start the boat by putting in 2 new batteries, but when I put my 2 new batteries in, the relay blew.
Sorry about the length of this post, but I would like to learn from this experience and I felt that this was the forum to get answers ( this is my first post). Thanks in advance for your insight and help
Rob
Las Vegas, NV
Rob
Las Vegas, NV
