Electrical load capacity
4runneradam
I have a 85hp Force 1985. Brand new stator. I was wondering what the charging output amperage is? I was wanting to install some small speakers and a small amp so I can hear my music over the outboard. The amp probably pulls 10-20 amps as the most. It's just a small 2 channel 65w amp. I was also looking at adding a cig lighter on the dash to power some small accessories as well.
Frank Acampora
Re: Electrical load capacity
That stator is not like an auto alternator. It only puts out around 7-10 amps. Only enough the keep the starting battery topped up and a very little more. So, even with the engine running, the amp will eventually run down the battery. The good news is that the engine has a dedicated circuit for ignition. Even with a completely dead battery, it will continue to run. Turn it off though and you may need to rope start it.
4runneradam
Hmm...interesting.
So do you think it would be safe to run a small amp? What if I kept an eye on the volt meter (which I plan to install) and make sure I shut the stereo down if it drops below 12v, and allow the motor to charge the battery back up?
roscoe
Just get an mp3 player with wireless headphones.
Keeps the lake a little quieter for the rest of us.
bcbaylinerboy
according to my seloc manual the 1984-1989 85hp puts out 1.0Amps @1000rpm and 7.0 Amps @3500rpm
You do the Math...maybe what you need is a seperate Battery to run your amp..and recharge it when you get home.
I had an amp in my boat..(120hp).and eventually blew my stator..so i ripped the amp out!
4runneradam
Oh. I don't want that. Thanks! I'll just stick with the head unit for now.
QuadManiac
FYI, I Installed a Sony CD head and a 300W amp w/ subwoofer last month. Carefully measured the current (average, not peak) after install at the loudest volume just prior to discernible distortion. Average current stayed between 5 and 7 amps, peaking at 10, but not very often. As long as you are not trying to 'Boom' your neighbors to death with your stereo, i believe the stator will handle it. Just in case, I bring along an extra battery and run the stereo from it most of the time. A 60 amp hour deep discharge battery will handle my stereo just fine all day, and then i can recharge it at night when i get home. That way, i can leave the stereo on when beached, and not worry about when i need to start the motor back up later.
I have a neighbor who put in, in his very nice boat, a stereo that was more expensive than my entire boat! You know the type... 8 speakers, 2 subwoofers, 5 amplifiers, etc. He doesn't understand why his battery won't hold a charge when running around with the stereo cranking all day, and he's got an I/O V8 with a 60A alternator, lol.
One word of caution: My stereo (when off, which turns amp off also) still draws 2.5 A, way more than you want if the boat is gonna sit for a couple of weeks. Either tie the switched power wire of the stereo to an Aux switch on your boat and turn the switch off when not in use; or i found that just removing the faceplate drops the current to only several milliamps. Not bad at all.
Good luck!
