electrical or plumbing?
beerfume
Hi y'all, I have an old Honda B100 (blue and white) 1979 I think, with points, in excellent cosmetic condition. It'll start first pull and troll all day long but burps, farts, surges and dogs out anywhere past half throttle. Any ideas? Would it be complicated to change over to electronic ignition?
sounds like you have a carb issue. not an ignition issue. sounds like a transition off idle problem like dirt in the main jet.
I would replace and adjust the points, clean and set the carb
