Electrical Power Surge
fireout47
I have a 1996 Tracker Pro Team 18 DC with a 40 HP Force. I was on the water last sunday and i noticed a few times that the volts would jump from 14 to 16-17. This happened on both the dash volt meter and the volt meter on my fish finder. I'm thinking voltage regulator? Any other ideas?
pnwboat
Re: Electrical Power Surge
That would be my guess too, but first check your ground connections from the regulator to the block. The regulator ground connection can be a separate black wire or the metal case of the rectifier itself.
