Electrical Question/Issue
MotorlessCSJ16
I noticed the other day that my exhaust housing had some ground wires (well I'm guessing that's what they were) that had rusted off. Here's a pic:
I attempted to reconnect them with some new wire and it seemed to work but, after driving home today, I noticed one came off again because I didn't secure it good enough.
I went to reconnect it only to get a vicious spark and it basically melted a little bit of wire.
I was just curious what the purpose of these are...are they necessary?
I was just going to leave them but, if they have something to do with the sensors, alarms, etc., that's not something I want to leave non-functioning.
Let me know!
Re: Electrical Question/Issue
Ayuh,... That a Continuity strap,... A Ground strap with an engineering degree...
They're usually a tinned copper braid wire...
It's part of the motor's bonding system to fight corrosion..
The Problem is,... There shoudn't be Any electrical current there....
I'd say you got a Serious Wiring issue somewhere, that's showing up at that strap...
CharlieB
Grab your trusty DC Volt meter and test between the motor and the boat, there should be NO voltage.
Which side is +, the boat or the motor?
Disconnect the positive cable from the battery , switch the meter to Ohms, test between the + battery cable and the boat or motor, whichever one was +.
Start checking everything electrical for the + connection to the hull or steering cable.
Do you have a cigarette lighter wired backwards?
