electrical/starter problem 200h.p 1989 yamaha
oddysea1
The starter is not getting any power to it.It is an new cond. The solenoid has been checked along with battery and terminals,along with power head in line fuse.The electric choke works along with gauges when key is on position.When turning key to start no draw is detected by volt gauge. As of sept. 24,POSSible fix,picked a short in neutral safety switch will change out when part comes in.
robert graham
Re: electrical/starter problem 200h.p 1989 yamaha
Is your emergency lanyard key in place? Is your throttle control in center/neutral position?:)
