- Mar 8, 2009
- 42,675
Dryer wiring 10/2 W ground
Older wiring where the ground is braid around the 2 conductors and appear to be tinned copper, rubber jacket not vinyl.
Hot wires are a tad to short in the breaker box, ground braid is plenty long. I'm thinking of using split bolt connectors inside the breaker box to make them longer to reach the breaker location. Could use wire nuts but I like split bolt and tape because they never loosen.
Questions are: is it code to make a connection inside the breaker panel? If not I have enough room to pull the cable out and put in a junction box besides it.
