Electro mechanical lift AQ270
captmello
Re: Electro mechanical lift AQ270
Your Picture isn't coming up but the only way is to remove the two allen head bolts at the base of the unit. Once those bolts are out the unit should pull out. If its corroded in the hole, put a large cresent wrench on the lift units upper housing and give it a turn to break it free. The unit should be able to spin in the hole with the bolts removed.
Let us know how it goes.:)
KIPU
It's realy spin in the hole but not able to put out
Is there some locks and any other secrets
captmello
from outside the boat behind the outdrive, you could put a small block of wood between the outdrive tilt arm and the foot of the lift. Give the outdrive a little push down to try to persuade the lift up out of the hole.
Good luck.:)
