electromatic
ski1966
Ihave a 1970 johnson electromatic can anybody tell me how it works and do you have to have the throttle handle make it go in gear any info would be very helpful thanks
Barnacle_Bill
Re: electromatic
It should be in fwd gear just sitting there. The motor has to be running to shift into neutral or reverse. Make sure you use type C or premium oil in the lower unit.
jjacobs007
Re: electromatic
still needs to be shifted,electromatic is not like automatic.
boobie
Re: electromatic
The throttle handle on that mtr moves a switch in the control box which in turn activates the solenoids in the g/c. but, the mtr has to be running to make it go into fwd or rev. The solenoids tell the oil pump in the g/c as to what gr to put it in and the mtr has to be running to make the oil pump work.
jay_merrill
Re: electromatic
Which engine do you have? Electromatic sounds like a 40hp, but if its a 55hp or 60hp, it would be a hydroelectric, which is a different system.
F_R
Re: electromatic
ELECTRAMATIC is electric clutches. Default is neutral when not running. There are no solenoids. Exhaust comes out above/rear of the propeller.
HYDRO_ELECTRIC is hydraulic shifted, electric solenoids operate control valves that cause the hydraulic system to shift it. Default is forward gear when not running. It must be running to shift out of forward. Exhaust comes out through the center of the propeller.
The two systems are totally different.
boobie
Re: electromatic
Boy, I won't post any more answers until I have a model #. Lesson learned!!
