electronic ignition kit from e-spark
eugene dix
hello my name is Eugene and I com from Holland.
a have a question.
I have a invader v177 whit a 3.0 mercruiser 130HP.
I botch a electronic ignition kit from www.e-spark.eu
the 3DEL4U1 and the ignition coil ES33HEC
I have read a lot about this.
one ting a am not sure what to do.
I must disconnect the resistance wires from the coil. and make a new wire.
Howe can a find de resistance wire?
but wear do i connect this new wire to, from coil to ?????
thank
alldodge
Howdy
I am assuming you have points and are changing over to electronic.
The resistance wire is the purple wire which was connected to the + side of the coil. The wire looks like any other purple wire. Remove and tap up the end of the wire
Your carb should have a purple wire on it and it is not resistive. Connect another wire to the choke wire and run it to the + side of the coil
Scott06
Check what size is there but I think 14 gauge or 1.5 mm will be good
