electronic ignition recommendation
jpcody66
I have a 1978 four cylinder mercruiser/GM 120 with the standard points and condenser ignition. Everyone I have talked to has recommended switching over to an electronic ignition. Is this advisable and if so, what brand/model would fit my motor and what all is necessary to make the conversion?
Dunaruna
Re: electronic ignition recommendation
Pertronix is a very popular conversion in boats. Visit their site and see if a kit is available for your motor.
Boomyal
Pertronix is a point/condensor replacement unit. It is an electronic switch instead of a electro-mechanical switch. It allows for a much stronger spark to get to the plugs without a set of points to burn up. Especially with the proper coil it does give you a better spark without any of the adjustment hassles of points. It is definitely a great place to start and maybe as far as you really need to go.<br /><br />It is not, however, a full electronic ignition system such as one of the various capacitive discharge or digital systems that can be used in conjunction with the Pertronix. Just be sure you get the Pertronix II version. It has 'key left on' protection and variable dwell. Without the (II) version, you leave key on, unit burns out!<br /><br />iboats ought to put some marine distributor versions in stock. They'd problably sell a lot of them.
FreeBeeTony
I used it on my IL6........worked great.<br /><br />I agree about th II version with the overtemp protection.
javsam
I just ordered a pertronix 2, the rep at carshop said to use the epoxy coil. would this be correct or should it be the oil filled one?<br />javsam
KaGee
Either one is fine. Epoxy is just more $$ out of your pocket, no real perfomance advantage. I bought the oil filled.
