Re: Electronic ignition
I like the Pertronix Ignitor conversion on my 1974 Mercruiser 140. I recommend you go with the Ignitor II, so you don't have to worry if you leave the ignition on too long without the engine running. Also, before you invest in this, I strongly recommend that you check the voltage at the coil positive post (CPP). Your 120 most likely have an externally-resisted coil. The external resistance is either in one or two ballast resistors, or more likely in a resistance cable in the wiring harness. My harness resistance cable was deteriorating, and as the engine compartment got hot, the resistance would increase. It got to the point where the CPP voltage would drop below 7.5V, and the Pertronix unit would shut down. Except you don't know that--all you know is the engine quits running. Very frustrating to troubleshoot. I eventually corrected that problem, but a huge problem was that the mechanic who installed the Ignitor didn't follow the directions. They say that, if you have external resistance, then do NOT attach the Ignitor positive lead to the CPP. Instead, attach it to a switchable 12V source. I tapped into the harness before the big plug. So, again, I would check the CPP voltage at various RPMs, and make sure the Ignitor gets wired right.<br /><br />Steve
