Re: Electronic Paddlewheel Spedometers
Paddle wheel speedometers are usually part of a depth finder / temp combo. You'll be hard put to find a stand alone system. If you do chose a combo, be advised that although they read consistent numbers, they are not too accurate. Paddle placement is very critical and the numbers can be affected by wash from sponsons or even heavy waves that cause the boat's attitude to change.
A GPS is cheap, but it shows ground speed. If you boat in waters that have a current you won't get true boat speed.
A brand name old fashioned pressure gauge / pitot tube speedometer is actually very accurate if installed correctly. That means proper pitot placement and a tube that is tightly sealed, no water intrusion and no kinks. The downside is that the lower end starts at about 6 or 7 mph, so if you need to know idle speed you won't get it.
If I go up and down river at cruise speed and average my GPS speed, its withing 1 mph of my pitot, which shows the same results going both ways. My paddle wheel is off by about 5 mph. Below plane at 8 mph, all 3 show the same results.
I use the paddle wheel to set the kicker speed for trolling, the tach to set the cruising speed and the GPS to find the fishing hole offshore.
