elettric fuel pump mercruiser 4.3
isla
Hello, a question, the electric pumps for gasoline that uses mercruiser / volvo are classic gear?
Have a picture where you can see the gears?
Thanks
achris
More fish than mountain goat
Re: elettric fuel pump mercruiser 4.3
The fuel pump is not a serviceable item and so there is no picture of the pump stripped down... If the pump is faulty, replace it. (with an OEM).
Chris..............
isla
Ok, but my question and 'another, and the pump' type gear?
sorry my english very bad
Ayuh,......
I believe that they are Georotor pumps.....
isla
Thank you!!!:rolleyes:
Don S
The gasoline seems to work fine, running dry for about 15 seconds (usually less) will destroy them.
