Eliminate thunderbolt system ?
Status
Not open for further replies.
kinger952
Is it possible to use thunderbolt distributor to go back to points and cond. ?
Old school is the best for me .
I would love to get rid of the elect ign period ( I know don't ask ) so much easier for me .
Scott06
Of course find a points distributor that is marine rated and fits your engine. Toss TB distributor and module take 12 v wire off positive terminal of coil put appropriate resistance in to feed coil during run
You will need to pick up 12 v off the starter slave solenoid or starter to supply full 12 v to coil during cranking
Ok Gotta ask why ?
kinger952
Ok Gotta ask why ?
I'm old school have worked with many point type distributors with NO ISSUES not like cdi which is hard for me to diagnose
achris
More fish than mountain goat
Simply put, no. There is no provision for a mechanical advance in the current distributor.
I get where you're coming from, but you won't find a points distributor for these engines. They don't exist, but as far as 'difficult to diagnose', Thunderbolt is about the easiest out there. It also took me a while to get my head around how they work, and now I do, they are very very simple.
Think of the sensor in the distributor as the 'timing' aspect of the points, and the module as current switching aspect of the points and you've got it nailed. The module does what the points do, switches the current running through the coil on and off. The sensor in the distributor tells the module WHEN to switch on and off. That's it!
Have a read of my document on understanding the system (link below) and look at the circus diagram... It's as simple a system as you can get.
Chris.........
kinger952
Chris.........
Thank you I will keep it.
but this is not really helping me with my throttling up issue I'm stimeyed on it. I've been wrenching all of my life and this one has got my 63 y/o. tail
achris
If it helps, I'm 62, and if I can understand it, anyone can. ;)
What's the engine (model, year, serial number) and what's the problem?
Chris...
Scott06
Agreed I like carbs myself but appreciate the electronic ignition. But as Chris lays out it is relatively easy to diagnose when understood
So yo have an issue when you accelerate? As Chris mentioned lay out what the issue is and what you are working on may not be ignition related.
kinger952
It is definitely spark related when I first moved distributor it ran strong on all 8 for a short while. I'm thinking advance is screwacky trying it tonight with timing light while throttling up
achris
I think this thread is about to dove-tail into your other thread, so I'll put a link to the other thread and close this one...
Chris.
iboats mod team
Status
