Emergency Kill Switch Wiring
hoowahfun
hi all, trying to wrap up some loose ends (literally) to get my project boat on the water. I discovered that the emergency kill switch is not wired up and I’m not sure which wires to splice them into. I’ve got a purple and purple/white wire coming from the switch, but haven’t been able to find anything about these two wires in the electrical diagrams. Ive also got two red/yellow wires that go to the dash and then another set that has purple, green, blue, and red. Any help is appreciated.
Bt Doctur
the MOB purple white to the ""I " post of the key switch and the purple spliced to the purple you removed from the ign switch
The Yellow/ red wires are the neutral safety ,1 to the "S" postion of the switch and the other to the yellow/red you removed from the switch
another set that has purple, green, blue, and red. is the trim tilt/trailer wiring that goes to the control box handel or a remote switch (s) on the dash
