If there's an electrical problem with a remote control motor and/or remote harness or plug (mine happens to be a 70 3 cyl but I think this applies to most) such as bad ignition switch, bad neutral lockout, no starter, etc. it appears that the "limp home" mode is as follows:<br />1) Pull the plug, disconnecting the remote.<br />2) Jump from the big red battery wire going to the starter solenoid to the small hot terminal (yellow on my motor) to engage the starter.<br />3) Drive home.<br /><br />How's this sound?
