I have a 96 johnson 70. I did not run it for several months. I took it out and it did not run on all cylinders and was very rough. I changed the sparkplugs and replaced the gas/water seprator filter. It was filthy. Any thoughts on the problem? Can I clean the carbs or do they need to be rebuilt?
Also, when I hooked up the flush and started the engin, the prop was spinning as if it was in gear. Any thoughts on what would cause that?
