Re: engin will not shut off
Initial idle mixture setting is 1 and 1/2 turns out from 'lightly' seated. This should provide enough fuel to start the motor. Adjust to 'Best' idle speed, 'IN' the water, plus almost another 1/8 turn to provide the additional fuel necessary for crisp acceleration.
If adjusting on the hose, turn @ 1/4 additional open after 'Best' idle, then recheck once on the water and up to temp.
Did you check the black wire w/yellow trace on the ignition switch to ensure it goes to 'ground'' with the key turned OFF?
I may have missed if that was pointed out, the lanyard and ignition switch, both should ground this wire to the solid black wire to kill spark and stop the motor. UN-plugging the main cannon plug or possibly a faulty connection here can also allow a motor to NOT kill. Sliding a small exacto-knife blade down the 'slit' of the male pins will widen them up to make a better connection, just don't over-do it and swell them too fat to go back together.
