harringtondav
- May 26, 2018
- 2,447
The effort I went through below wouldn't be bad for an engine pull, but was a bit much for yearly maintenance.
I needed to tear the boat down this far to access the fuel filter and recirculating pump impeller. Also I needed to access the fuel filter housing to change fittings to allow a 2 stroke premix fuel can for engine fogging. ...more on that later.
Learning curve and some simplifications will make it easier next fall. SS wood screws driven into the aluminum beam will be gone. I'll tap the holes and avoid gumming the phillips head and having to drill out the screw. The bottom three holes for the access panel had loose SS lock nuts. ...one is still in the bilge. ...no idea how Regal put it together, or how I will. So I'll bond marine plywood behind and use the SS wood screws.
DIY can be a pain, but much less expensive than the $135/hr marina techs doing it.
