[FONT=Helvetica, Arial, sans-serif]Need your help guys! So Saturday I launched my boat for the first time this season and Sunday was the day for the maiden voyage. 7.4 MPI Mercruiser. A few issues that happened. 1) A beep tone alarm went off at cruising 3200 rpm and would not go away until I shut the engine off. It was occurring about every 5 seconds and would not shut off. Water temperature was at 170 which is what it always runs at, oil pressure was good in the 40 range and gear oil tank was full. After I shut the engine off and restarted, the alarm has gone off again and seems to come on at around 3000 rpm. Tested at idle speed and WOT. The engine however will still reach WOT with the alarm on so its not a rev limiter. I disconnected the gear oil sender to see if alarm would stop and nothing changed. Checked the thermostat with a infrared gun and read at about 155 at the time of the alarm going off. I basically did process of elimination at this point. Checked the battery volts and alternator, all was good. Checked the engine temp and oil pressure and that was good. Also checked all fluid levels, oil, power steering, trim pump, gear oil, trim tab pump and all that is good. I do not know what else to look for. If anyone can point me in the right direction would be greatly appreciated. Thank You [/FONT] [h=1][/h]
