Engine Alarm Wiring
sr54x4
Had to put a new VDO oil pressure sending unit in my boat last night. I connected the light blue wire to the gauge post on the sending unit. Everything works. Went to connect the tan wire with the light blue tracer line, which should be for the engine alarm, and when I touched it to the post it sparked. Turns out I have 12v going through this wire at all times, key on and off, even batteries switched to off. Is this normal? I actually don't have an engine alarm installed right now, the previous owner took it out for some reason. I was just hooking up that tan wire so it wasnt dangling in the engine bay. A full alarm system is on the "to-do" list. Right now, just need to know if the engine alarm wire is supposed to have 12V? I am having trouble tracing where that wire goes to. Pretty sure its not, as that tan wire should go to a ground and when the switches closes it sends ground to the buzzer and completes the circuit?
alldodge
Would be real good to know what motor your working on. Sure we could go back thru the threads you posted and maybe figure it out, but cut us some slack.
Normally yes the Tan/Blue wire is grounded and this turns on the alarm. There should not be 12V on this wire with the ignition off.
sr54x4
Sorry about that, thought my boat details were in the signature. This is on a 1988 Formula 242 SS with a 7.4 Mercruiser
achris
More fish than mountain goat
Those alarms have a delay circuit built in. There is a capacitor in the alarm module, that's where you are seeing the 12v from after the battery is disconnected. The tan/blue wire is connected to a different oil pressure switch, not the one for the gauge.
sr54x4
Ok, ill have to put the meter on the wire again after some time has gone by to see if it still has power or not.
The VDO sender I put in had two posts on it as it is a combo alarm switch/gauge sender. It said the "G" post was for the gauge and the "Wk" post was for the low pressure alarm.
achris
Ensure the alarm post is normally closed.
