I had to pull my 4.3 Mercruiser due to a leaky Y pipe. It turns out the shop that installed the rebuilt engine before I bought the boat did not use the right transom hardware setup, specifically the washers between engine and transom mount. That let the bolts run to far through the mounting nuts and the end of the bolts dug into the Y pipe and pierced a pin hole that was making a little water geyser when the boat was in the water. During reassembly I also found the aluminum mounting nuts had been stripped out and were just tight enough to let the bolts draw down inside of them, but not enough to actually be torqued. All problems were corrected, but when I inserted the alignment bar, I had to adjust the front mounts up a good inch or so to get good engagement with no drag when turned. The mounts were previously at their lowest setting, so much so that I actually had to pull them off the block and run the nuts up high enough to get the wrench to fit.
Would a lack of rear washers/spacers cause that much of a change in alignment? With the mounts as low as they were the fuel/water filter was sitting almost completely tight to the string so removing and replacing it was a real pain. Now there is lots of room for removing/accessing things.
I had replaced my bellows and gimbal bearing last year with the engine at its previous height with no issues. Alignment bar fit just fine. I just need my mind put at ease as to why such a drastic change would be needed?
