Hey guys. I just installed the gimbal bearing and was working on aligning the engine but ran into a problem. I slid the alignment tool in with a little coaxing (i figured i would adjust the front motor mounts to the point where it would slide out easily). Then the problem, there is no adjustment for the mounts. The "ears" coming off the block are resting on the pads that are bolted to the floor of the boat. The only nut holding it on is on the top, no two adjustment buts in between. I know the boat ('02 Four Winns) was repowered with alot of mercruiser parts instead of Volvo Penta (didnt know when i bought it). Are the two styles of mounts different that much? Any thoughts on how to correct it? The driver slid off pretty easily (Volvo Penta SX-M) and I only replaced the gimbal bearing due to water intrusion. Any help would be greatly appreciated. I'm at a loss.
