Engine Alignment
system-f
1971 Merc 165 Engine alignment
How far should the alignment tool go in past the gimbal bearing?
I can adjust the engine up and it gets tight...down a little and it is smooth, down a little more and it is tight again...but I juts want to make sure it is going in far enough. I think it goes in 7-8" past the gimbal bearing.
bigskiohio
Master Chief Petty Officer
Re: Engine Alignment
use grease on the tool and then you could tell how deep your going. how far it goes i dont have a measurement but mine would bottom out.
cr2k
You want to see even grooves in the grease all the way around the tool, AND ease of insertion and removal.
Ayuh,... The shoulder on the alignment bar should be firmly against the gimbel bearing...
