engine back fires at 3200 rpms
blueagletalon
i have a merc 470 four cyclender and i have the carb rebuilt. now it back fires at 3200 rpms. it it the carb or something else.
havasuboatman
Ensign
Re: engine back fires at 3200 rpms
That would depend on whether of not it did this before the carb was re built.
If it did, probably not the carb, but another part of fuel delivery. Fuel pump, lines, etc. that are causing a lean fuel condition.
If it didn't, then yep, most likely a mis-adjusted carb.
180shabah
Need more info.
Could be fuel, fuel pump, fuel filter, carb, fuel tank vent, timing, vacuum leak, etc.....
blueagletalon
what more info do u need. it did not have the problem till the carb was rebuilt.
blueagletalon
we had a problem with it getting to much gas and fouling out the plugs.
180shabah
What troubleshooting has been done to eliminate items listed above?
