Check for a lean condition, fuel filter(s), fuel pump pressure/vacuum, incorrect timing, ignition system components old/failingany suggestions (2001 4.3 litre mercruiser)
Ayuh,.... Welcome Aboard,...... Check the Contents of the fuel filter, for anything but clean fresh gasoline,.....Ok thanks will start checking above, appreciate the reply
I have a 2001 4.3. Was doing same thing , replaced wires, filters, s plugs, coil, was still backfiring , turned out to be faulty thermostat changed it and boat runs like a top.Could also be a crossfire from Spark Plug Wires or Distributor Cap. Acceleration increases the Voltage required to fire the Plug and Electricity doesn't where it goes, as long as it can complete the Circuit.
