Engine Break in
BRG25
Just bought a 19' 2000 Stingray with 4.3L V6 Mercruiser I/O. What would indicate that the engine was/wasn't properly broken in? I'm not expierencing any problems except my Tach isn't working and I'm not positive I'm reaching WOT until I repair it. It gets right up on plane and will do 50 mph easily. The boat was bought new by a friend of mine who just passed away reciently and I don't think his wife would be able to answer this question. Thanks.<br /><br />Brian
tmclendon
Re: Engine Break in
50mph is pretty good for a 19' with a 4.3, I don't think you have any problems.<br /><br />As far as break in, modern engines are pretty hard to mess up. All I can think of is maybe the rings would not 'seal' properly to the cylinder walls so you would see/smell a little oil, and you would need to add some oil between changes, which you should not have to do on a new engine.<br /><br />Tom
BRG25
Re: Engine Break in
Thanks Tom, I do periodically see some smoke initally on startup, not just cold but also restarting when the engine is warm. It goes away immediatly. Is this normal? My 3.0 never did this.
karayj
Re: Engine Break in
got a 4.3 alpha 1 205 hp 18ft I get about 52 out of it on a 1/2 tansk of gas seems normal
