Engine Build up
Themanofsteel
I have a Force Outboard 85hp. There is some white crusty stuff that builds up at the bottom of my engine on one side only. Anyone know what it's from and why.
jerryjerry05
You should fill out the profile.
​Trying to figure out a problem like this and us knowing if your running in a lake or salt water will help.
In my signature I tell people I live in Fl. and boat in the salt.
​The problem: looks like a leak. Then it dries and leaves the crust/ minerals.
In salt water it would be salt.
​It looks like the gasket between the block and the adaptor plate has failed..
​The fix: pull the motor and replace the gasket and use a bunch of sealer.
​One of my motors started leaking in the same spot.
​I just covered it with silicone. Still working after 3 years.
