Engine Change
Bhamil
I have a 21', 1988 Bayliner Trophy with cuddy cabin. It has a hard top and is in very good condition. Currently the engine is a 3.0L GM and I have been thinking about changing it. Does anyone know what will go in there? And, what do you recommend?
BMDODGE
Re: Engine Change
unless it's another 4-banger it's going to take some work - i believe Bondo did a 3.0L to a 4.3..<br />21' with a 3.0l - WOW - what's top speed at WOT ??? good luck - bruce
Trent
Re: Engine Change
Ben it will COST! Unless you remove it from another boat. Your going to need manifolds, brackets, and most likely modify the floor/stringers for the bigger engine. Most times its not worth the money unless you have deep pockets. Also will have to change the gearing in the outdrive.
Bhamil
Re: Engine Change
BMDODGE; Do I detect a bit of sarcasm there? I'll have you know that at WOT I can almost leave a wake; I can speed through a NO-WAKE zone and the folks dock-side don't notice the difference! That's why I was cornsidering a different engine.
Re: Engine Change
Trent's got this 1 covered........ ;) <br /><br />The Only Way to do it is,<br />Bone-Out a Donor boat for All the Parts.....<br />Once you get passed Destroying a Perfectly Good Running Boat, <br />It's a Piece of Cake...... :D
Trent
Re: Engine Change
Ditto.... What Bondo said. Just buy another boat!
Bhamil
Re: Engine Change
Got it!! I'm especially fond of the feedback that reads;<br />"Once you get passed Destroying a Perfectly Good Running Boat,"...that warms the cockles of my heart. I think I'll keep what I got, cause I ain't got the money (or the heart) to tear up another boat for this one.
Bhamil
Re: Engine Change
charleswmoore; thanks for the info. I think I talked myself out of the engine change, with a little help from my friends here, butI went to this site and did some reading; all Bayliner enthusiasts there and some have made pretty neat and often off-the-wall comments (that's not an insult). It's an excellent site, and I thank you again for the post.
