Engine compression
tom2
Hi,<br />I have a 1977 70 HP Johnson and would like to know what the compression should be. I took a compression test and all 3 cylinders show 105 pounds. Should this engine run good?<br />Thanks,Tom
DHPMARINE
Re: Engine compression
I consider these readings good for a 1977 engine. You may also want to do a spark test,and do a fuel sample.<br /><br />DHP
