Hey all, I was attempting to start my 1978 85hp evidence when I shut the key off it continued to crank and the negative cable began smoking. I ripped it off the battery and the cranking stopped. The ignition snitch checked out ok. Out of curiosity I grounded a test light to the negative post of the battery and touched it to the engine block and it came on. I appear to have voltage running through my motor???. I started moving the starter solenoid around and the voltage disappeared. Can a starter solenoid go bad and direct current from its positive side to its ground (the block)
