this 2.3 liter ford engine will every once in a while turn over the starter and keep on cranking. after i notice its acting up i'll turn off switch. only way to get it to stop is to disconnect battery cables. three times i have replaced the starter solenoid. im no mechanic but i think thats the name for it. my old ford car had one on the fender well if this helps at all. a mechanic told me that these solenoids stick if there is low voltage. but im useing the battery out of my truck. never had a problem starting it.was wondering what amp the buss fuses should be.i was given this boat and have had good luck so far this seems to be the only problem i've really had with it. there was also a spare solenoid laying in the engine compartment when i got the boat. so he has had same thing happening to him.
