Engine died while cruising down water
ahunter4063
The last time i went boating the engine just died for no apparant reason. do i need to replace the oil pressure switch? I have already replaced the spark plugs. Thanks for the help!
tpenfield
Re: Engine died while cruising down water
If the engine died for no apparent reason, why would you need to replace the oil pressure switch?
Tell us more about the situation . . . gauge readings, did it start back up ? , etc.
