Engine dies when shut down quickly
glastron86
Another question...when I am tubing with the family, someone may fall off of the tube and I throttle back quickly to nuetral, the motor has started to die. It will restart and run just fine, this has only happened a couple of times, is there something about this that I should be checking out?
Coors
Re: Engine dies when shut down quickly
backwash coming up the exhaust?
Slow down easy, to keep your engine from ingesting water thru the exhaust
Don S
If you have a Mercruiser, it could have a lower shift cable starting to go bad. This will cause the engine to die when coming out of gear.
Coors
Don is alive and well?
How was the move?
glastron86
Thanks for the replies! Yes I do have a Mercruiser 470, Alpha One. If it is because of the lower shift cable, then this could also relate to another thread I had involving my transmission grinding a little bit when I shift from forward or nuetral to reverse?
Ayuh,............ That could be 1 in the Same Problem..............
180shabah
I think we are on to something here
