Engine fault codes
ATOMIX
Hello got fault codes on volvo penta GXI-J 5.0liter went into OEM mode and got these codes but don't have a code reader .everything seems ok with motor just hard steering ,hasnt been started for a year but had full service and replaced control cable and started ok,these are the fault codes i am getting but system tells me only caution alarms and to check manual but manual doesn't have codes.
MID 128,SID 151,FMI 14
Steering has little to do with the motor
alldodge
Unable to find that combination. Can find MID 128 but not with the other 2. MID 128 EVC code is common but need more to narrow down
muc
"Retired" Association of Marine Technicians...
Hello ATOMIX welcome to the board.
if you can post your serial number it makes it SO much easier for one of us Volvo dealer technicians to look up the info you need.
QBhoy
If it’s anyrhing like the 5.0 Merc MPI...there are always a few alarms present when reading codes and errors or plugged into the reader.
THese are relating to sensors that aren’t fitted on that particular engine.
Can’t remember what they are right now, but will be well documented on here and internet.
At least 4 or 5 of them.
