Engine Flush Adaptor
Taz59
I need an adaptor to connect to the hose to flush the Engine out, what size is the thread ?
Fun Times
Thanks for starting a new topic. The other topic referenced in the following link is considered an archive now so please no need to bring it back up, thank you.. http://forums.iboats.com/forum/engin...d-in-saltwater
In the referenced topic above there was a parts guide that may have helped you some..Here it is again,
http://www.volvopentastore.com/Seawa...view_id.773560
Item # 22 part number 3807440 looks to be a connector.
Below is some info regarding a kit for this flush system...Maybe it will help out some.
With this kit installed, all you should need to do is connect a normal sized water hose up to the lower blue connector once you removed the top cap/cover...Is that what you're after info wise?
GARDEN HOSE ENGINE FLUSH PROJECT
Estimated time, start to finish:
1 hour
What you get:
Flush kit for gas engines, allows you to run your engine while connected to a 3/4" garden hose. Hose connects to the blue cap in the picture. This is a standard feature on recent Volvo Penta gas engines.
Cost of parts:
$24.15
Parts required:
(please note there are different parts depending on your engine hose diameter)
While Volvo Penta does not sell this as a kit, we have determined that these are the parts you will need: 3862656 (Cap), 3862082 (Retainer), 3862079 (Gasket), 3807440 (Flushing connection), 978174 (hose clamps, you need two), 982645 (more hose clamps, also quantity two), 3857823 (hose) clamp (3862891) screw (formerly 3853557 but now expired as of 6/1/2011--you will need to supply your own screw #7 in the diagram) and 3862699 (T-pipe for 1" pipe). Just to be clear: don't try to order the expired screw online, the shopping cart will allow you to do it, but then our parts department will call you to tell you it is no longer available.
If you have a 1-1/4 in. engine pipe: then you need a different T-pipe, 3589415 and 2 larger clamps: 3853786.
fetch
Taz59
Guys
The kit is already fitted, I just need the garden hose adaptor that screws into the fitting, the picture attached is the plug that you remove, I am struggling to find out the thread size, not sure if its metric or imperial,
Fun Times
https://www.youtube.com/watch?v=zM6LdNmPT4c
http://forums.iboats.com/forum/engin...5#post10182065
Garden hose adapter size: Garden hoses connect using a male/female thread connection. Spigots typically have male connectors, and one end of a hose has a captive nut which fits the threads. The technical term for this arrangement is a "hose union".
The thread standard for garden hose connectors in the United States, its territories and Canada is known as "garden hose thread" (GHT), which is [SUP]3[/SUP]⁄[SUB]4[/SUB] inch (19 mm) diameter straight (non-tapered) thread with a pitch of 11.5 threads per inch (TPI). The female thread is abbreviated FHT and the male part MHT which has an outer diameter of 1 [SUP]1[/SUP]⁄[SUB]16[/SUB] inches (27 mm). This fitting is used with  [SUP]1[/SUP]⁄[SUB]2[/SUB]-inch,  [SUP]5[/SUP]⁄[SUB]8[/SUB]-inch, and  [SUP]3[/SUP]⁄[SUB]4[/SUB]-inch hoses.[SUP][1][/SUP][SUP][2][/SUP] In other countries, a British Standard Pipe (BSP) thread is used, which is  [SUP]3[/SUP]⁄[SUB]4[/SUB] inch and 14 TPI (male part outside diameter is 26.441 mm or 1.04 in). The GHT and BSP standards are not compatible, and attempting to connect a GHT hose to a BSP fitting will damage the threads, and vice versa.
Each male end of a typical garden hose can mate with the female connector on another, which allows multiple garden hoses to be linked end-to-end to increase their overall length. Small rubber or plastic washers (often confusingly called "hose washers") are used in female ends to prevent leakage, because the threads are not tapered and are not used to create a seal. Sometimes the gaskets stiffen, disintegrate, or fall out of older hoses, which results in pressurized leakage spraying from the hose; simply replacing the washer insert often fixes the problem.
