Engine going back in this weekend NEED ADVICE !
Cast-A-Way
Hi guy's
My resto is almost done !!
The outdrive is on ( Cobra )
I am planning on putting the engine ( 4.3 OMC ) this weekend
How do I ensure that the transom plate ,outdrive and engine shaft is aligned ?
I noticed that I have some adjustment points with the transom plate and also with the engine mount
the boat is an 18 feet avanti industries bowrider
the bell housing ?? is still on the engine
Any tips for me
I have attached a very brutal drawing of what it looks like
Thank you in advance
drewpster
Re: Engine going back in this weekend NEED ADVICE !
I have not done it myself, I do not own any outdrives. I have however seen it done with a special tool. Also the engine was already in and then the outdrive was installed after it. I know this is no real help, but you may have to have an alignment tool to do it.:redface:
D
DJ
Guest
I'll move this to the I/O section. You should get responses there.
proshadetree
Pull the outdrive back off and install engine.Then use alignment tool,can find for about 50 bucks on ebay youll be glad you did.And money ahead
Cast-A-Way
Thank you Don S
This will really help out
