engine height
Johnson110
my engine 110 omc is mounted with the cav plate even with bottom on the boat can i go up 1 hole higher, i am getting 5600 rpms now that is with a stainless steel prop, is it safe to go higher? :confused:
Silvertip
Re: engine height
You can go to 6000 RPM but by raising the engine you need to be concerned about loss of water pressure so a water pressure gauge is recommended. One hole should not be a problem. Any higher than that and you need to be careful.
