Engine Hours
Status
Not open for further replies.
tbauer
I am considering purchasing a used boat. I was wondering what should be considered a lot of hours on an engine.<br /><br />For instance, I am currently looking at boat built in 1994 with 560 hours on it.<br /><br />Is that a few? A lot? Or just about right?<br /><br />Thanks for the help in advance.
Walter
Re: Engine Hours
That averages out to 70 hours per year. That's not excessive...but it's definitely been used!<br />You don't mention anything about the engine. Make, model, etc... That info would be very helpful.<br /><br />Walt
tbauer
Re: Engine Hours
The engine is in a 1994 Hydrodyne Grand Sport. It has a Ford PCM 351 EFI engine. The current owner states the it has been professionally maintained and and winterized.
Walter
Re: Engine Hours
Those are nice boats!<br /><br />As with any used boat purchase...I'd suggest having a qualified mechanic thoroughly check it out. Compression test...etc...<br /><br />No sense in buying someone else's headache!<br /><br />Walt
flashback
Re: Engine Hours
thats not a lot of hours if the engine has been cared for. shoot. a thousand hours is not much if the engine has been cared for..guess what I'm trying to say is maintainance........does it run well, no smoke,no overheating, no knocks a clanks.
D
DJ
Guest
Re: Engine Hours
Ogel,<br /><br />500 plus hours, is a testament to the good care it received.<br /><br />2000 hours on a marine inboard or I/O is easily attainable with good care. Many have much more.<br /><br />FYI, you will probably be looking at manifold and riser replacements, unless it has a full closed cooling system.
Status
