Engine Identification #
kpkrol
I am replacing my engine and need to know how to find the VIN # so I can make sure I get the same rotation I have now (standard vs reverse). Can I get this from title? <br /><br />The engine is a GM 350 magnum 5.7L from a '91 Celebrity bowrider 200. <br /><br />HULL ID = CLC11233B191<br /><br />Thanks in advance.
Rhadley
Re: Engine Identification #
I assume you mean engine serial number. If it isn't on the engine somewhere (as it's supposed to be), look on your title. It should be there.
The #s Should be down low on the Starboard side of the Block.........<br /><br />I Absolutely Guarantee you have a Standard rotation engine.........<br /><br />A Plain Old 350 Chevy.........
